Curating academic publications — a perspective for research libraries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2010
The talk identifies and discuss the editorial and technical background that is now essential to fulfil the core roles of a research library with regards to scholarly publication. As the role of the library continues to evolve, Research Librarians will be required to provide more and more support to researchers to maintain, archive and disseminate their scholarly content – which includes research papers, data and other materials. The presentation will explore some of the technologies being deployed by librarians and in particular the role of international standardization initiatives such as the TEI (Text Encoding Initiative). It will also examine the library- publisher relationship and the need for publishers and librarians to work together to address the requirements of their patrons. The EU PEER project will be taken as an example of such collaborations.
ALPSP-talk.pdf (890.1 Ko) Télécharger le fichier
inria-00517052 , version 1 (13-09-2010)
  • HAL Id : inria-00517052 , version 1
Laurent Romary. Curating academic publications — a perspective for research libraries. ALPSP International Conference 2010, Sep 2010, Wyboston, United Kingdom. ⟨inria-00517052⟩
Collections
INRIA INRIA2
72 Consultations
64 Téléchargements
