Texture Analysis and Classification With Linear Regression Model Based on Wavelet Transform - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The wavelet transform as an important multiresolution analysis tool has already been commonly applied to texture analysis and classification. Nevertheless, it ignores the structural information while capturing the spectral information of the texture image at different scales. In this paper, we propose a texture analysis and classification approach kith the linear regression model based on the wavelet transform. This method is motivated by the observation that there exists a distinctive correlation between the sample images, belonging to the same kind of texture, at different frequency regions obtained by 2-D wavelet packet transform. Experimentally, it was observed that this correlation varies from texture to texture. The linear regression model is employed to analyze this correlation and extract texture features that characterize the samples. Therefore, our method considers not only the frequency regions but also the correlation between these regions. In contrast, the pyramid-structured wavelet transform (PSWT) and the treestructured wavelet transform (TSWT) do not consider the correlation between different frequency regions. Experiments show that our method significantly improves the texture classification rate in comparison with the multiresolution methods, including PSWT, TSWT, the Gabor transform, and some recently proposed methods derived from these.
Zhi-Zhong_Wang2008a.pdf (2.19 Mo) Télécharger le fichier
inria-00517305 , version 1 (14-09-2010)
  • HAL Id : inria-00517305 , version 1
Zhi-Zhong Wang, Jun-Hai Yong. Texture Analysis and Classification With Linear Regression Model Based on Wavelet Transform. IEEE Transactions on Image Processing, Oct 2008, California, United States. ⟨inria-00517305⟩
58 Consultations
413 Téléchargements
