Progressive interpolation using loop subdivision surface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
A new method for constructing interpolating Loop subdivision surfaces is presented. The new method is an extension of the progressive interpolation technique for B-splines. Given a triangular mesh M, the idea is to iteratively upgrade the vertices of M to generate a new control mesh M' such that limit surface of M' interpolates M. It can be shown that the iterative process is convergent for Loop subdivision surfaces. Hence, the method is well-defined. The new method has the advantages of both a local method and a global method, i.e., it can handle meshes of any size and any topology while generating smooth interpolating subdivision surfaces that faithfully resemble the shape of the given meshes.
Cheng2008a_LNCS_Proof.pdf (701.65 Ko) Télécharger le fichier
inria-00517350 , version 1 (14-09-2010)
  • HAL Id : inria-00517350 , version 1
Fuhua Cheng, Fengtao Fan, Shuhua Lai, Conglin Huang, Jiaxi Wang, et al.. Progressive interpolation using loop subdivision surface. Proceedings of Geometric Modeling and Processing 2008, Apr 2008, Hangzhou, China. ⟨inria-00517350⟩
59 Consultations
254 Téléchargements
