A New Algorithm for Boolean Operations on General Polygons - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computers and Graphics Année : 2005
Yu Peng
  • Fonction : Auteur
Jun-Hai Yong
  • Fonction : Auteur
Hui Zhang
  • Fonction : Auteur
Jia-Guang Sun
  • Fonction : Auteur
A new algorithm for Boolean operations on general planar polygons is presented. It is available for general planar polygons (manifold or non-manifold, with or without holes). Edges of the two general polygons are subdivided at the intersection points and touching points. Thus, the boundaryof the Boolean operation resultant polygon is made of some whole edges of the polygons after the subdivision process. We use the simplex theory to build the basic mathematical model of the new algorithm. The subordination problem between an edge and a polygon is reduced to a problem of determining whether a point is on some edges of some simplices or inside the simplices, and the associated simplicial chain of the resultant polygon is just an assembly of some simplices and their coefficients of the two polygons after the subdivision process. Examples show that the running time required bythe new algorithm is less than one-third of that bythe Rivero and Feito algorithm.
YuPeng2005a.pdf (752.87 Ko) Télécharger le fichier
inria-00517670 , version 1 (15-09-2010)
Yu Peng, Jun-Hai Yong, Wei-Ming Dong, Hui Zhang, Jia-Guang Sun. A New Algorithm for Boolean Operations on General Polygons. Computers and Graphics, 2005, 29 (1), pp.57-70. ⟨10.1016/j.cag.2004.11.001⟩. ⟨inria-00517670⟩
412 Consultations
1893 Téléchargements
