A torus patch approximation approach for point projection on surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Aided Geometric Design Année : 2009
Xiao-Ming Liu
  • Fonction : Auteur
Lei Yang
  • Fonction : Auteur
Jun-Hai Yong
  • Fonction : Auteur
Jia-Guang Sun
  • Fonction : Auteur
This paper proposes a second order geometric iteration algorithm for point projection and inversion on parametric surfaces. The iteration starts from an initial projection estimation. In each iteration, we construct a second order osculating torus patch to the parametric surface at the previous projection. Then we project the test point onto the torus patch to compute the next projection and its parameter. This iterative process is terminated when the parameter satisfies the required precision. Experiments demonstrate the convergence speed of our algorithm.
Xiao-MingLiu2009a_CAGD.pdf (1.04 Mo) Télécharger le fichier
inria-00517719 , version 1 (15-09-2010)
  • HAL Id : inria-00517719 , version 1
Xiao-Ming Liu, Lei Yang, Jun-Hai Yong, He-Jin Gu, Jia-Guang Sun. A torus patch approximation approach for point projection on surfaces. Computer Aided Geometric Design, 2009. ⟨inria-00517719⟩
84 Consultations
769 Téléchargements
