ubiSOAP: A Service Oriented Middleware for Ubiquitous Networking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Services Computing Année : 2010
The computing and networking capacities of today's wireless portable devices allow for ubiquitous services, which are seamlessly networked. Indeed, wireless handheld devices now embed the necessary resources to act as both service clients and providers. However, the ubiquitous networking of services remains challenged by the inherent mobility and resource constraints of the devices, which make services a priori highly volatile. This paper discusses the design, implementation and experimentation of the ubiSOAP service-oriented middleware, which leverages wireless networking capacities to effectively enable the ubiquitous networking of services. ubiSOAP specifically defines a layered communication middleware that underlies standard SOAP-based middleware, hence supporting legacy Web Services while exploiting nowadays ubiquitous connectivity.
main.pdf (1.04 Mo) Télécharger le fichier
inria-00519577 , version 1 (20-09-2010)
  • HAL Id : inria-00519577 , version 1
Mauro Caporuscio, Pierre-Guillaume Raverdy, Valérie Issarny. ubiSOAP: A Service Oriented Middleware for Ubiquitous Networking. IEEE Transactions on Services Computing, 2010. ⟨inria-00519577⟩
Collections
INRIA INRIA2
185 Consultations
511 Téléchargements
