On the Stock Estimation for a Harvested Fish Population - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Bulletin of Mathematical Biology Année : 2012
We consider a stage-structured model of a harvested fish population and we are interested in the problem of estimating the unknown stock state for each class. The model used in this work to describe the dynamical evolution of the population is a discrete time system including a nonlinear recruitment relationship. To estimate the stock state, we build an observer for the considered fish model. This observer is an auxiliary dynamical system that uses the catch data over each time interval and gives a dynamical estimate of the stock state for each stage class. The observer works well even if the recruitment function in the considered model is not well known. The same problem for an age-structured model has been addressed in a previous work [26].
BMAB-D-10-00202f.pdf (1.09 Mo) Télécharger le fichier
inria-00523963 , version 1 (06-10-2010)
inria-00523963 , version 2 (26-05-2011)
Aboudramane Guiro, Abderrahman Iggidr, Diène Ngom. On the Stock Estimation for a Harvested Fish Population. Bulletin of Mathematical Biology, 2012, 74 (1), pp.116-142. ⟨10.1007/s11538-011-9667-z⟩. ⟨inria-00523963v2⟩
218 Consultations
295 Téléchargements
