Extension de la notion de verbe support - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
The notion of light verb (support verb) is traditionally used for verbs which have an object (direct or indirect) which is a predicative noun (Npred) denoting an eventuality. It has been extended by Melc'uk, among others, to cover cases in which a Npred is the head of a GN subject. This paper studies structures with a Npred as the head of a nominal subject It shows that two structures must be distinguished: those which involve a real notion extending that of a support verb, and the other ones which boil down to ordinary structures.
Vsup-CRL.pdf (137.14 Ko) Télécharger le fichier
inria-00524746 , version 1 (08-10-2010)
  • HAL Id : inria-00524746 , version 1
Laurence Danlos. Extension de la notion de verbe support. T. Nakamura and E. Laporte and A. Dister and C. Fairon. Les Tables, La grammaire par le menu, Volume d'hommage à Christian Leclère, Presses Universitaires de Louvain, pp.81--90, 2010. ⟨inria-00524746⟩
162 Consultations
256 Téléchargements
