Targeting Reconfigurable FPGA based SoCs using the MARTE UML profile: from high abstraction levels to code generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Embedded Systems Année : 2010
As SoC design complexity is escalating to new heights, there is a critical need to find adequate approaches and tools to handle SoC co-design aspects. Additionally, modern reconfigurable SoCs offer advantages over classical SoCs as they integrate adaptivity features to cope with mutable design requirements and environment needs. This paper presents a novel approach to address system adaptivity and reconfigurability. A generic model of reactive control is presented in a SoC codesign framework: Gaspard. Afterwards, control integration at different levels of the framework is illustrated for both functional specification and FPGA synthesis. The presented work is based on Model-Driven Engineering and the UML MARTE profile proposed by Object Management Group, for modeling and analysis of real-time embedded systems. The paper thus presents a complete design flow to move from high level MARTE models to code generation, for implementation of dynamically reconfigurable SoCs.
ijes09_yu_sub_version.pdf (2.08 Mo) Télécharger le fichier
inria-00525015 , version 1 (10-10-2010)
inria-00525015 , version 2 (10-11-2010)
  • HAL Id : inria-00525015 , version 1
Imran Rafiq Quadri, Abdoulaye Gamatié, Samy Meftali, Jean-Luc Dekeyser, Huafeng Yu, et al.. Targeting Reconfigurable FPGA based SoCs using the MARTE UML profile: from high abstraction levels to code generation. International Journal of Embedded Systems, 2010, 18 p. ⟨inria-00525015v1⟩
Collections
LIFL
387 Consultations
525 Téléchargements
