A Contrastive Indexing Method and its Integration in Aquarelle Folders - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
The Aquarelle1 architecture is designed and built in a user oriented perspective. Folder archiving, indexing and retrieval must thus be designed for data access through «user friendly», yet expeditious, methods. This is a major challenge to the Information Systems in the Aquarelle organisation. This document addresses the role of advanced full text indexing in delivering data access and archiving applications. Our aim is to investigate the effective use of structured folders using automatic or assisted indexing in a multimedia and multilingual environment.
Delos.pdf (25.07 Ko) Télécharger le fichier
inria-00525130 , version 1 (11-10-2010)
  • HAL Id : inria-00525130 , version 1
Patrice Bonhomme, Laurent Romary. A Contrastive Indexing Method and its Integration in Aquarelle Folders. Cross-Language Information Retrieval - third Delos workshop, Mar 1997, Zurich, Switzerland. ⟨inria-00525130⟩
71 Consultations
49 Téléchargements
