Instant Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2003
This paper presents a new method for the automatic modeling of architecture. Building designs are derived using split grammars, a new type of parametric set grammar based on the concept of shape. The paper also introduces an attribute matching system and a separate control grammar, which offer the flexibility required to model buildings using a large variety of different styles and design ideas. Through the adaptive nature of the design grammar used, the created building designs can either be generic or adhere closely to a specified goal, depending on the amount of data available.
instant_architecture.pdf (13.94 Mo) Télécharger le fichier
Format : Figure, Image
inria-00527500 , version 1 (19-10-2010)
  • HAL Id : inria-00527500 , version 1
Peter Wonka, Michael Wimmer, François X. Sillion, William Ribarsky. Instant Architecture. ACM Transactions on Graphics, 2003, 22 (4), pp.669 -- 677. ⟨inria-00527500⟩
359 Consultations
1722 Téléchargements
