Synchronization of chaotic systems via reduced observers
This paper treats synchronization problem of chaotic systems from a novel point of view, by using a change of coordinates to transform chaotic systems into a common canonical form, for which the synchronization problem can be easily studied via reduced observer. Sufficient and neces- sary conditions are given and the proposed method is illustrated by the synchronization of R ̈ossler chaotic system.
Automatique
