Mse Lower Bounds Conditioned by the Energy Detector - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
A wide variety of processing incorporates a binary detection test that restricts the set of observations for parameter estimation. This statistical conditioning must be taken into account to compute the Cramér-Rao bound [1] (CRB) and more generally, lower bounds on the Mean Square Error (MSE) [2]. Therefore, we propose a derivation of some lower bounds-including the CRB-for the deterministic signal model conditioned by the energy detector [3] widely used in signal processing applications .
vincent_164.pdf (258.52 Ko) Télécharger le fichier
inria-00532904 , version 1 (21-09-2019)
inria-00532904 , version 2 (17-03-2020)
  • HAL Id : inria-00532904 , version 1
Eric Chaumette, Jérôme Galy, Francois Vincent, Alexandre Renaux, Pascal Larzabal. Mse Lower Bounds Conditioned by the Energy Detector. EUSIPCO: European Signal Processing Conference, Sep 2007, Poznan, Poland. pp.586-590. ⟨inria-00532904v1⟩
354 Consultations
206 Téléchargements
