Stabilizing data-link over non-FIFO channels with optimal fault-resilience - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
Self-stabilizing systems have the ability to converge to a correct behavior when started in any configuration. Most of the work done so far in the self-stabilization area assumed either communication via shared memory or via FIFO channels. This paper is the first to lay the bases for the design of self-stabilizing message passing algorithms over unreliable non-FIFO channels. We propose a fault-send-deliver optimal stabilizing data-link layer that emulates a reliable FIFO communication channel over unreliable capacity bounded non-FIFO channels.
DolevDuboisPotopTixeuil.pdf (179.63 Ko) Télécharger le fichier
inria-00536048 , version 1 (15-11-2010)
inria-00536048 , version 2 (07-02-2011)
  • HAL Id : inria-00536048 , version 2
  • ARXIV : 1011.3632
Shlomi Dolev, Swan Dubois, Maria Potop-Butucaru, Sébastien Tixeuil. Stabilizing data-link over non-FIFO channels with optimal fault-resilience. [Research Report] ???. 2010. ⟨inria-00536048v2⟩
187 Consultations
421 Téléchargements
