Uniform Confluence in Concurrent Computation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal on Functional Programming Année : 2000
Joachim Niehren
Indeterminism is typical for concurrent computation. If several concurrent actors compete for the same resource then at most one of them may succeed, whereby the choice of the successful actor is indeterministic. As a consequence, the execution of a concurrent program may be nonconfluent. Even worse, most observables (termination, computational result, and time complexity) typically depend on the scheduling of actors created during program execution. This property contrast concurrent programs from purely functional programs. A functional program is uniformly confluent in the sense that all its possible executions coincide modulo reordering of execution steps. In this paper, we investigate concurrent programs that are uniformly confluent and their relation to eager and lazy functional programs. We study uniform confluence in concurrent computation within the applicative core of the pi-calculus which is widely used in different models of concurrent programming (with interleaving semantics). In particular, the applicative core of the pi-calculus serves as a kernel in foundations of concurrent constraint programming with first-class procedures (as provided by the programming language Oz). We model eager functional programming in the lambda-calculus with weak call-by-value reduction and lazy functional programming in the call-by-need lambda-calculus with standard reduction. As a measure of time complexity, we count application steps. We encode the lambda-calculus with both above reduction strategies into the applicative core of the pi-calculus and show that time complexity is preserved. Our correctness proofs employs a new technique based on uniform confluence and simulations. The strength of our technique is illustrated by proving a folk theorem, namely that the call-by-need complexity of a functional program is smaller than its call-by-value complexity. The unabridged version of this article is available from Uniform:99. Due to lack of space, the journal version does not contain the encoding of the delta-calculus (introduced in the paper) into the applicative core of the pi-calculus which is of its own interest.
Uniform_2000.pdf (439.63 Ko) Télécharger le fichier
inria-00536801 , version 1 (16-11-2010)
  • HAL Id : inria-00536801 , version 1
Joachim Niehren. Uniform Confluence in Concurrent Computation. Journal on Functional Programming, 2000, 10 (5), pp.453-499. ⟨inria-00536801⟩
58 Consultations
217 Téléchargements
