A Confluent Relational Calculus for Higher-Order Programming with Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1994
We present the rho-calculus, a relational calculus parametrized by a logical constraint system. The rho-calculus provides for higher-order relational programming with first-order constraints, and subsumes higher-order functional programming as a special case. It captures important aspects of the concurrent constraint programming language Oz. We prove the uniform confluence of the rho-calculus. Uniform confluence implies that all maximal derivations issuing from a given expression have equal length. But even confluence of a nonfunctional calculus modelling computation with partial information is interesting on its own right.
RhoCCL94.pdf (268.52 Ko) Télécharger le fichier
inria-00536826 , version 1 (16-11-2010)
  • HAL Id : inria-00536826 , version 1
Joachim Niehren, Gert Smolka. A Confluent Relational Calculus for Higher-Order Programming with Constraints. 1st International Conference on Constraints in Computational Logics, 1994, Munich, Germany. ⟨inria-00536826⟩
84 Consultations
281 Téléchargements
