Comparing the performance of two TAG-based surface realisers using controlled grammar traversal
We present GENSEM, a tool for generating input semantic representations for two sentence generators based on the same reversible Tree Adjoining Grammar. We then show how GENSEM can be used to produced large and controlled benchmarks and test the relative performance of these generators.
Informatique et langage [cs.CL]
