Real-Time Dynamic Wrinkles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
This paper proposes a new method for designing dynamic wrinkles that appear and disappear according to the underlying deformation of tissues. The user positions and orients wrinkling tools on a mesh. During animation, geometric wrinkles are generated in real-time in the regions covered by the tools, mimicking resistance to compression of tissues. The wrinkling feature can be added to any existing animation. When the local resolution of the mesh is not sufficient, our tool refines it according to the wrinkles finest feature. As our results show, the technique can be applied to a variety of situations such as facial expression, joint or garment wrinkles.
larboulette04.pdf (187.67 Ko) Télécharger le fichier
hand.avi (2.95 Mo) Télécharger le fichier
trousers.avi (3.59 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
inria-00537455 , version 1 (18-11-2010)
Caroline Larboulette, Marie-Paule Cani. Real-Time Dynamic Wrinkles. Computer Graphics International (CGI'04), Jun 2004, Crete, Greece. pp.522-525, ⟨10.1109/CGI.2004.1309258⟩. ⟨inria-00537455⟩
340 Consultations
515 Téléchargements
