Capturing the Complexity of Hair Motion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Graphical Models Année : 2002
Modelling the highly inelastic interactions inside hair, and between the hair and the character body is a determinant feature for achieving realistic hair animation. However, the extremely large number of hair strands has so far prevented animators from handling these interactions. It is also unclear if they should be treated at the level of individual hair strands. This paper proposes an approach to handle these interactions, based on a new clustering paradigm. The high friction forces between neighboring hair strands, yielding a high motion coherence, is simulated by clustering these strands into an anisotropic viscous volume representing a hair wisp. All other interactions between hair strands are approximated at the wisp level, thanks to an anisotropic behavior that allows pairs of wisps to interpenetrate or to collide depending on their relative orientations. The wisps also offer the necessary structure to efficiently simulate the collisions with the character body. The model results in visually-realistic animations, where complex wisp interactions capture both continuities and discontinuities easily observed in thick, long hair.
Plante-2002-CCHM.pdf (594.29 Ko) Télécharger le fichier
long-final-cut.mov (2.73 Mo) Télécharger le fichier
maria-compare.tif (132.71 Ko) Télécharger le fichier
medium-final-cut.mov (2.49 Mo) Télécharger le fichier
short-final-cut.mov (2.36 Mo) Télécharger le fichier
stephanie.mpg (1.79 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00537496 , version 1 (18-11-2010)
Eric Plante, Marie-Paule Cani, Pierre Poulin. Capturing the Complexity of Hair Motion. Graphical Models, 2002, 64 (1), pp.40--58. ⟨10.1006/gmod.2002.0568⟩. ⟨inria-00537496⟩
273 Consultations
680 Téléchargements
