Implicit Representations in Computer Animation : a Compared Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
How can Implicit Surfaces be used in the context of high-end Computer Animation ? This paper compares two different representations of field functions – the constructive approach and the field image approach. Their respective advantages and limitations for the definition of animation and morphing algorithms, and for the visualization of an animation are discussed. We show that efficient solutions to the animation of textured objects can be provided by hybrid methods that combine these representations together and/or with parametric surfaces. This point is illustrated by two case studies: the animation of deformable characters and the simulation of textured lava-flows.
caniIS99.pdf (388.52 Ko) Télécharger le fichier
inria-00537514 , version 1 (18-11-2010)
  • HAL Id : inria-00537514 , version 1
Marie-Paule Cani. Implicit Representations in Computer Animation : a Compared Study. Implicit Surfaces, 1999, Bordeaux, France. ⟨inria-00537514⟩
105 Consultations
370 Téléchargements
