Heuristics for the Multicriteria Routing Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Alia Bellabas
  • Fonction : Auteur
  • PersonId : 881074
Miklos Molnar
Samer Lahoud
In current networks, the applications require more and more quality of services. Hence, a routing algorithm has to satisfy several constraints such as delay, bandwidth or jitter. This is called multicriteria routing problem. Since the multicriteria routing is an NP-Hard problem, we propose heuristics that quickly compute paths that satisfy Quality of service (QoS) constraints between a source node and a destination node. Several solutions exist in the literature; SAMCRA (Self Adaptive Multiple Constraints Routing Algorithm) is one of the most efficient algorithms, that was proposed by Van Mieghem et al. in 2001. SAMCRA is an exact unicast multi-constrained algorithm, which may have a high combinatorial complexity. In our paper, we investigate the possibility to replace SAMCRA by an improved k shortest paths algorithm. The simulation results show that applying such an algorithm significantly reduces the computation time while giving satisfying solutions.
Fichier non déposé
inria-00538293 , version 1 (22-11-2010)
  • HAL Id : inria-00538293 , version 1
Alia Bellabas, Miklos Molnar, Samer Lahoud. Heuristics for the Multicriteria Routing Problem. Mosharaka International Conference on Communications Computers and Applications, Oct 2009, Amman, Jordan. ⟨inria-00538293⟩
198 Consultations
0 Téléchargements
