Using Evolution Strategy with Meta–models for Well Placement Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2010
Didier Yu Ding
  • Function : Author
  • PersonId : 866478
Anne Auger
  • Function : Author
  • PersonId : 751513
  • IdHAL : anne-auger
Optimum implementation of non-conventional wells allows us to increase considerably hydrocarbon recovery. By considering the high drilling cost and the potential improvement in well productivity, well placement decision is an important issue in field development. Considering complex reservoir geology and high reservoir heterogeneities, stochastic optimization methods are the most suitable approaches for optimum well placement. This paper proposes an optimization methodology to determine optimal well location and trajectory based upon the Covariance Matrix Adaptation - Evolution Strategy (CMA-ES) which is a variant of Evolution Strategies recognized as one of the most powerful derivative-free optimizers for continuous optimization. To improve the optimization procedure, two new techniques are investigated: (1). Adaptive penalization with rejection is developed to handle well placement constraints. (2). A meta-model, based on locally weighted regression, is incorporated into CMA-ES using an approximate ranking procedure. Therefore, we can reduce the number of reservoir simulations, which are computationally expensive. Several examples are presented. Our new approach is compared with a Genetic Algorithm incorporating the Genocop III technique. It is shown that our approach outperforms the genetic algorithm: it leads in general to both a higher NPV and a significant reduction of the number of reservoir simulations.
Bouzarkouna_et_al._Ecmor2010.pdf (600.82 Ko) Télécharger le fichier
Dates and versions
inria-00538745 , version 1 (23-11-2010)
Identifiers
  • HAL Id : inria-00538745 , version 1
  • ARXIV : 1011.5481
Cite
Zyed Bouzarkouna, Didier Yu Ding, Anne Auger. Using Evolution Strategy with Meta–models for Well Placement Optimization. ECMOR XII – 12 th European Conference on the Mathematics of Oil Recovery, EAGE (European Association of Geoscientists & Engineers), Sep 2010, Oxford, United Kingdom. ⟨inria-00538745⟩
268 View
196 Download
Share
