Formal Verification of Consensus Algorithms in a Proof Assistant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Consensus is regarded as the fundamental problem that must be solved to implement a fault-tolerant distributed system. It requires nodes to eventually agree on a common value among the initial values held by each of them. Agreement should be reached despite the failures of some components (process or link). Depending on the timing and failure models, numerous Consensus algorithms have been proposed in the literature. We are studying techniques for proving the correctness of these algorithms using the interactive proof assistant Isabelle, aiming for a high level of automation.
sho-isabelle.pdf (28.32 Ko) Télécharger le fichier
inria-00539899 , version 1 (25-11-2010)
  • HAL Id : inria-00539899 , version 1
Henri Debrat, Bernadette Charron-Bost, Stephan Merz. Formal Verification of Consensus Algorithms in a Proof Assistant. 2010 Grande Region Security and Reliability Day, Mar 2010, Saarbrücken, Germany. ⟨inria-00539899⟩
286 Consultations
185 Téléchargements
