Programming Real-Time Applications with Signal - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the IEEE Année : 1991
This paper presents the main features of the Signal language and its compiler. Designed to provide safe real time system programming, the Signal language is based on the synchronous principles. Its semantics is defined via a mathematical model of multiple-clocked flows of data and events. Signal programs describe relations on such objects, so that it is possible to program a real time application via constraints. The compiler calculates the solutions of the system and may thus be used as a proof system. Moreover, the equational approach is a natural way to derive multiprocessor executions of a program. Finally, this approach meets the intuition through a graphical interface of block-diagram style, and the system is illustrated on a speech recognition application.
ProcIEEE-91_gen_lang.pdf (383.76 Ko) Télécharger le fichier
inria-00540460 , version 1 (29-11-2010)
Paul Le Guernic, Thierry Gautier, Michel Le Borgne, Claude Le Maire. Programming Real-Time Applications with Signal. Proceedings of the IEEE, 1991, Another look at Real-time programming, 79 (9), pp.1321-1336. ⟨10.1109/5.97301⟩. ⟨inria-00540460⟩
161 Consultations
868 Téléchargements
