Genus 2 point counting over prime fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2012
Éric Schost
  • Fonction : Auteur
  • PersonId : 839026
For counting points of genus 2 curves over a large prime field, the best known approach is essentially an extension of Schoof's genus 1 algorithm. We propose various practical improvements to this method and illustrate them with a large scale computation: we counted hundreds of curves, until one was found that is suitable for cryptographic use, with a state-of-the-art security level of approximately 2^128 and desirable speed properties. This curve and its quadratic twist have a Jacobian group whose order is 16 times a prime.
countg2.pdf (391.84 Ko) Télécharger le fichier
inria-00542650 , version 1 (03-12-2010)
Pierrick Gaudry, Éric Schost. Genus 2 point counting over prime fields. Journal of Symbolic Computation, 2012, 47 (4), pp.368-400. ⟨10.1016/j.jsc.2011.09.003⟩. ⟨inria-00542650⟩
291 Consultations
666 Téléchargements
