Incremental displacement-correction schemes for the explicit coupling of a thin structure with an incompressible fluid - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Comptes Rendus. Mathématique Année : 2011
In this note we propose two incremental displacement-correction schemes for the explicit coupling of a thin structure with an incompressible fluid. The stability and the superior accuracy of these schemes (with respect to the original non-incremental variant) are theoretically analyzed and then numerically confirmed in a benchmark.
RR-7474.pdf (216.78 Ko) Télécharger le fichier
inria-00542917 , version 1 (03-12-2010)
Miguel Angel Fernández. Incremental displacement-correction schemes for the explicit coupling of a thin structure with an incompressible fluid. Comptes Rendus. Mathématique, 2011, 349 (7-8), pp.473-477. ⟨10.1016/j.crma.2011.03.001⟩. ⟨inria-00542917⟩
142 Consultations
241 Téléchargements
