Fluid-particles flows: a thin spray model with energy exchanges - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Proceedings Année : 2009
This paper is devoted to an asymptotic analysis of a fluid-particles coupled model, in the bubbling regime. On the theoretical point of view, we extend the analysis done by Carrillo, Goudon and Lafitte for the case of an isentropic gas to the case of an ideal gas, thus adding the internal energy, or temperature, which is unknown. We formally derive the bubbling limit system and propose a numerical scheme to solve this limit system.
inria-00543156 , version 1 (06-12-2010)
Laurent Boudin, Benjamin Boutin, Bruno Fornet, Thierry Goudon, Pauline Lafitte, et al.. Fluid-particles flows: a thin spray model with energy exchanges. ESAIM: Proceedings, 2009, CEMRACS 2008 - Modelling and Numerical Simulation of Complex Fluids, 28, pp.195-210. ⟨10.1051/proc/2009047⟩. ⟨inria-00543156⟩
372 Consultations
0 Téléchargements
