Subgrid-scale treatment for major point sources in an Eulerian model: A sensitivity study on the European Tracer Experiment (ETEX) and Chernobyl cases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Geophysical Research Année : 2010
We investigate the plume-in-grid method for a subgrid-scale treatment of major point sources in the passive case. This method consists in an on-line coupling of a Gaussian pu model and an Eulerian model, which better represents the point emissions without signicantly increasing the computational burden. In this paper, the plume-in-grid model implemented on the Polyphemus air quality modeling system is described, with an emphasis on the parameterizations available for the Gaussian dispersion, and on the coupling with the Eulerian model. The study evaluates the model for passive tracers at continental scale with the ETEX experiment and the Chernobyl case. The aim is to (1) estimate the model sensitivity to the local-scale parameterizations, and (2) to bring insights on the spatial and temporal scales that are relevant in the use of a plume-in-grid model. It is found that the plume-in-grid treatment improves the vertical diusion at local-scale, thus reducing the bias -- especially at the closest stations. Doury's Gaussian parameterization and a column injection method give the best results. There is a strong sensitivity of the results to the injection time and the grid resolution. The "best" injection time actually depends on the resolution, but is difficult to determine a priori. The plume-in-grid method is also found to improve the results at ne resolutions more than with coarse grids, by compensating the Eulerian tendency to over-predict the concentrations at these resolutions.
korsakissok10subgrid.pdf (1.52 Mo) Télécharger le fichier
inria-00543214 , version 1 (06-12-2010)
inria-00543214 , version 2 (06-01-2014)
Irène Korsakissok, Vivien Mallet. Subgrid-scale treatment for major point sources in an Eulerian model: A sensitivity study on the European Tracer Experiment (ETEX) and Chernobyl cases. Journal of Geophysical Research, 2010, 115 (D03303), ⟨10.1029/2009JD012734⟩. ⟨inria-00543214v1⟩
Collections
ENPC ENPC-CEREA
184 Consultations
226 Téléchargements
