Early detection of bovine respiratory disease in young bulls using reticulo-rumen temperature boluses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Veterinary Journal Année : 2010
The use of reticulo-rumen temperature boluses to detect bovine respiratory disease (BRD) was investigated in young bulls following their entry into a fattening unit. Twenty-four bulls received a bolus at entry and were observed for 40 days. As soon as a reticulo-rumen hyperthermia (RH) episode was detected using the bolus, clinical examination was performed by a veterinarian and then repeated every 12-24 h until the end of RH episode. Fifty-two RH episodes were detected in 22 animals. High rectal temperatures (40.1 ± 0.6 °C) were observed during these episodes. BRD was diagnosed on the basis of clinical examination during 38/52 RH episodes in 21 animals (positive predictive value 73%). The onset of BRD signs always occurred after the onset of RH episodes, with a time-lag from 12 to 136 h, depending on BRD signs. Monitoring reticulo-rumen temperature permits early detection of BRD; however, clinical examination is required to confirm BRD.
inria-00543356 , version 1 (06-12-2010)
Edouard Timsit, Sébastien Assié, René Quiniou, Henri Seegers, Nathalie Bareille. Early detection of bovine respiratory disease in young bulls using reticulo-rumen temperature boluses. Veterinary Journal, 2010, 190 (1), pp.136-142. ⟨10.1016/j.tvjl.2010.09.012⟩. ⟨inria-00543356⟩
203 Consultations
0 Téléchargements
