Specifying and Implementing an Eventual Leader Service for Dynamic Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
The election of an eventual leader in an asynchronous system prone to process crashes is an important problem of faulttolerant distributed computing. This problem is known as the implementation of the failure detector . Nearly all papers that propose algorithms implementing such an eventual leader service consider a static system. In contrast this paper considers a dynamic system, i.e., a system in which processes can enter and leave. The paper has three contributions. It first proposes a specification of suited to dynamic systems. Then, it presents and proves correct an algorithm implementing this specification. Finally, the paper discusses the notion of an eventual leader suited to dynamic systems. It introduces an additional property related to system stability. The design of an algorithm satisfying this last property remains an open challenging problem.
PI-1962.pdf (448.85 Ko) Télécharger le fichier
inria-00543977 , version 1 (07-12-2010)
  • HAL Id : inria-00543977 , version 1
Mikel Larrea, Michel Raynal. Specifying and Implementing an Eventual Leader Service for Dynamic Systems. [Research Report] PI 1962, 2010, pp.8. ⟨inria-00543977⟩
197 Consultations
437 Téléchargements
