Efficient Bayesian inference for harmonic models via adaptive posterior factorization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Neurocomputing Année : 2008
Harmonic sinusoidal models are an essential tool for music audio signal analysis. Bayesian harmonic models are particularly interesting, since they allow the joint exploitation of various priors on the model parameters. However existing inference methods often rely on specific prior distributions and remain computationally demanding for realistic data. In this article, we investigate a generic inference method based on approximate factorization of the joint posterior into a product of independent distributions on small subsets of parameters. We discuss the conditions under which this factorization holds true and propose two criteria to choose these subsets adaptively. We evaluate the resulting performance experimentally for the task of multiple pitch estimation using different levels of factorization.
vincent_Neurocomp08.pdf (244.25 Ko) Télécharger le fichier
inria-00544176 , version 1 (07-12-2010)
  • HAL Id : inria-00544176 , version 1
Emmanuel Vincent, Mark D. Plumbley. Efficient Bayesian inference for harmonic models via adaptive posterior factorization. Neurocomputing, 2008, 72, pp.79--87. ⟨inria-00544176⟩
191 Consultations
175 Téléchargements
