Abstract : In the present paper, a general multiobjective optimization problem is stated as a Nash game. In the nonrestrictive case of two objectives, we address the problem of the splitting of the design variable between the two players. The so-called territory splitting problem is solved by means of an allocative approach. We propose two algorithms in order to find fair allocation tables.
https://hal.inria.fr/inria-00544355 Contributor : Abderrahmane HabbalConnect in order to contact the contributor Submitted on : Tuesday, December 7, 2010 - 5:03:00 PM Last modification on : Saturday, June 25, 2022 - 11:05:35 PM Long-term archiving on: : Tuesday, March 8, 2011 - 4:53:51 AM
