a Sparse Texture Representation Using Affine-Invariant Neighborhoods Regions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper introduces a texture representation suitable for recognizing images of textured surfaces under a wide range of transformations, including viewpoint changes and nonrigid deformations. At the feature extraction stage, a sparse set of affine-invariant local patches is extracted from the image. This spatial selection process permits the computation of characteristic scale and neighborhood shape for every texture element. The proposed texture representation is evaluated in retrieval and classification tasks using the entire Brodatz database and a collection of photographs of textured surfaces taken from different viewpoints.
lana_cvpr03.pdf (2.54 Mo) Télécharger le fichier
inria-00548232 , version 1 (20-12-2010)
Svetlana Lazebnik, Cordelia Schmid, Jean Ponce. a Sparse Texture Representation Using Affine-Invariant Neighborhoods Regions. International Conference on Computer Vision & Pattern Recognition (CVPR '03), Jun 2003, Madison, United States. pp.319--324, ⟨10.1109/CVPR.2003.1211486⟩. ⟨inria-00548232⟩
216 Consultations
470 Téléchargements
