Optimal Estimation of Matching Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
We describe work in progress on a numerical library for estimating multi-image matching constraints, or more precisely the multi-camera geometry underlying them. The library will cover several variants of homographic, epipolar, and trifocal constraints, using various different feature types. It is designed to be modular and open-ended, so that (i) new feature types or error models, (ii) new constraint types or parametrizations, and (iii) new numerical resolution methods, are relatively easy to add. The ultimate goal is to provide practical code for stable, reliable, statistically optimal estimation of matching geometry under a choice of robust error models, taking full account of any nonlinear constraints involved. More immediately, the library will be used to study the relative performance of the various competing problem parametrizations, error models and numerical methods. The paper focuses on the overall design, parametrization and numerical optimization issues. The methods described extend to many other geometric estimation problems in vision, e.g. curve and surface fitting.
Triggs-smile98.pdf (244.95 Ko) Télécharger le fichier
Triggs-smile98-slides.pdf (136.03 Ko) Télécharger le fichier
Format : Autre
inria-00548324 , version 1 (20-12-2010)
Bill Triggs. Optimal Estimation of Matching Constraints. Workshop on 3D Structure from Multiple Images of Large-scale Environments (SMILE), Jun 1998, Freiburg, Germany. pp.63--77, ⟨10.1007/3-540-49437-5_5⟩. ⟨inria-00548324⟩
155 Consultations
431 Téléchargements
