Learning to Track 3D Human Motion from Silhouettes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Ankur Agarwal
  • Fonction : Auteur
  • PersonId : 844845
Bill Triggs
This paper describes a sparse Bayesian regression method for recovering 3D human body motion directly from silhouettes extracted from monocular video sequences. No detailed body shape model is needed, and realism is ensured by training on real human motion capture data. The tracker estimates 3D body pose by using Relevance Vector Machine regression to combine a learned autoregressive dynamical model with robust shape descriptors extracted automatically from image silhouettes. We studied several different combination methods, the most effective being to learn a nonlinear observation-update correction based on joint regression with respect to the predicted state and the observations. We demonstrate the method on a 54-parameter full body pose model, both quantitatively using motion capture based test sequences, and qualitatively on a test video sequence.
Agarwal-icml04.pdf (1.53 Mo) Télécharger le fichier
video11icml.avi (4.3 Mo) Télécharger le fichier
video18icml.avi (439.35 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
inria-00548549 , version 1 (20-12-2010)
Ankur Agarwal, Bill Triggs. Learning to Track 3D Human Motion from Silhouettes. 21st International Conference on Machine Learning (ICML '04), Jul 2004, Banff, Canada. pp.9--16, ⟨10.1145/1015330.1015343⟩. ⟨inria-00548549⟩
174 Consultations
330 Téléchargements
