Weakly supervised learning of visual models and its application to content-based retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2004
This paper presents a method for weakly supervised learning of visual models. The visual model is based on a two-layer image description: a set of "generic" descriptors and their distribution over neighbourhoods. "Generic" descriptors represent sets of similar rotational invariant feature vectors. Statistical spatial constraints describe the neighborhood structure and make our description more discriminant. The joint probability of the frequencies of "generic" descriptors over a neighbourhood is multi-modal and is represented by a set of "neighbourhood-frequency" clusters. Our image description is rotationally invariant, robust to model deformations and characterizes efficiently "appearance-based" visual structure. The selection of distinctive clusters determines model features (common to the positive and rare in the negative examples). Visual models are retrieved and localized using a probabilistic score. Experimental results for "textured" animals and faces show a very good performance for retrieval as well as localization.
schmid_ijcv2004.pdf (420.71 Ko) Télécharger le fichier
inria-00548553 , version 1 (20-12-2010)
Cordelia Schmid. Weakly supervised learning of visual models and its application to content-based retrieval. International Journal of Computer Vision, 2004, Special Issue on Content-Based Image Retrieval, 56 (1), pp.7--16. ⟨10.1023/B:VISI.0000004829.38247.b0⟩. ⟨inria-00548553⟩
112 Consultations
378 Téléchargements
