Flexible Object Models for Category-Level 3D Object Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Today's category-level object recognition systems largely focus on fronto-parallel views of objects with characteristic texture patterns. To overcome these limitations, we propose a novel framework for visual object recognition where object classes are represented by assemblies of partial surface models (PSMs) obeying loose local geometric constraints. The PSMs themselves are formed of dense, locally rigid assemblies of image features. Since our model only enforces local geometric consistency, both at the level of model parts and at the level of individual features within the parts, it is robust to viewpoint changes and intra-class variability. The proposed approach has been implemented, and it outperforms the state-of-the-art algorithms for object detection and localization recently compared in [14] on the Pascal 2005 VOC Challenge Cars Test 1 data.
akash_cvpr.pdf (1.05 Mo) Télécharger le fichier
inria-00548682 , version 1 (20-12-2010)
Akash Kushal, Cordelia Schmid, Jean Ponce. Flexible Object Models for Category-Level 3D Object Recognition. CVPR - IEEE Conference on Computer Vision & Pattern Recognition, Jun 2007, Minneapolis, United States. pp.1-8, ⟨10.1109/CVPR.2007.383149⟩. ⟨inria-00548682⟩
378 Consultations
319 Téléchargements
