Two Linear Time Union-Find Strategies for Image Processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 1996
We consider Union-Find as an appropriate data structure to obtain two linear time algorithms for the Segmentation of images. The linearity is obtained by restricting the Order in which Union's are performed. For one algorithm the complexity bound is proven by amortizing the Find operations. For the other we use periodic updates to keep the relevant part of our Union-Find-tree of constant height. Both algorithms are generalized and lead to new linear strategies for Union-Find that are neither covered by the algorithm of Gabow and Tarjan (1984) nor by the one of Dillencourt et al. (1992).
82650509.pdf (1.08 Mo) Télécharger le fichier
inria-00549539 , version 1 (05-09-2019)
Christophe Fiorio, Jens Gustedt. Two Linear Time Union-Find Strategies for Image Processing. Theoretical Computer Science, 1996, 154 (2), pp.165-181. ⟨10.1016/0304-3975(94)00262-2⟩. ⟨inria-00549539⟩
124 Consultations
400 Téléchargements
