Sparsity regret bounds for individual sequences in online linear regression - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2011
We consider the problem of online linear regression on arbitrary deterministic sequences when the ambient dimension d can be much larger than the number of time rounds T. We introduce the notion of sparsity regret bound, which is a deterministic online counterpart of recent risk bounds derived in the stochastic setting under a sparsity scenario. We prove such regret bounds for an online-learning algorithm called SeqSEW and based on exponential weighting and data-driven truncation. In a second part we apply a parameter-free version of this algorithm to the stochastic setting (regression model with random design). This yields risk bounds of the same flavor as in Dalalyan and Tsybakov (2011) but which solve two questions left open therein. In particular our risk bounds are adaptive (up to a logarithmic factor) to the unknown variance of the noise if the latter is Gaussian. We also address the regression model with fixed design.
gerchinovitz13a.pdf (308.85 Ko) Télécharger le fichier
inria-00552267 , version 1 (05-01-2011)
inria-00552267 , version 2 (17-03-2012)
inria-00552267 , version 3 (12-04-2013)
  • HAL Id : inria-00552267 , version 3
  • ARXIV : 1101.1057
Sébastien Gerchinovitz. Sparsity regret bounds for individual sequences in online linear regression. Journal of Machine Learning Research, 2011, 14, pp.729-769. ⟨inria-00552267v3⟩
266 Consultations
325 Téléchargements
