Generalizing AGM to a multi-agent setting - Archive ouverte HAL Access content directly
Journal Articles Logic Journal of the IGPL Year : 2010
(1, 2)
1
2
We generalize AGM belief revision theory to the multi-agent case. To do so, we first generalize the semantics of the single-agent case, based on the notion of interpretation, to the multi-agent case. Then we show that, thanks to the shape of our new semantics, all the results of the AGM framework transfer. Afterwards we investigate some postulates that are specific to our multi-agent setting. Finally, we give an example of revision operator that fulfills one of these new postulates and give an example of revision on a concrete example.
logic_journal_of_IGPL.pdf (385.85 Ko) Télécharger le fichier
Dates and versions
inria-00556032 , version 1 (29-09-2011)
Identifiers
Cite
Guillaume Aucher. Generalizing AGM to a multi-agent setting. Logic Journal of the IGPL, 2010, 18 (4), pp.530-558. ⟨10.1093/jigpal/jzp037⟩. ⟨inria-00556032⟩
101 View
374 Download
Share
