The Structure of First-Order Causality (extended version) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Structures in Computer Science Année : 2011
Game semantics describe the interactive behavior of proofs by interpreting formulas as games on which proofs induce strategies. Such a semantics is introduced here for capturing dependencies induced by quantifications in first-order propositional logic. One of the main difficulties that has to be faced during the elaboration of this kind of semantics is to characterize definable strategies, that is strategies which actually behave like a proof. This is usually done by restricting the model to strategies satisfying subtle combinatorial conditions, whose preservation under composition is often difficult to show. Here, we present an original methodology to achieve this task, which requires to combine advanced tools from game semantics, rewriting theory and categorical algebra. We introduce a diagrammatic presentation of the monoidal category of definable strategies of our model, by the means of generators and relations: those strategies can be generated from a finite set of atomic strategies and the equality between strategies admits a finite axiomatization, this equational structure corresponding to a polarized variation of the notion of bialgebra. This work thus bridges algebra and denotational semantics in order to reveal the structure of dependencies induced by first-order quantifiers, and lays the foundations for a mechanized analysis of causality in programming languages.
mimram_mscs11.pdf (482.78 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
inria-00559240 , version 1 (25-01-2011)
Samuel Mimram. The Structure of First-Order Causality (extended version). Mathematical Structures in Computer Science, 2011, 21 (01), pp.65-110. ⟨10.1017/S0960129510000459⟩. ⟨inria-00559240⟩
104 Consultations
108 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
