Total variation regularization for fMRI-based prediction of behaviour. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Medical Imaging Année : 2011
While medical imaging typically provides massive amounts of data, the extraction of relevant information for predictive diagnosis remains a difficult challenge. Functional MRI (fMRI) data, that provide an indirect measure of taskrelated or spontaneous neuronal activity, are classically analyzed in a mass-univariate procedure yielding statistical parametric maps. This analysis framework disregards some important principles of brain organization: population coding, distributed and overlapping representations. Multivariate pattern analysis, i.e., the prediction of behavioural variables from brain activation patterns better captures this structure. To cope with the high dimensionality of the data, the learning method has to be regularized. However, the spatial structure of the image is not taken into account in standard regularization methods, so that the extracted features are often hard to interpret. More informative and interpretable results can be obtained with the '1 norm of the image gradient, a.k.a. its Total Variation (TV), as regularization. We apply for the first time this method to fMRI data, and show that TV regularization is well suited to the purpose of brain mapping while being a powerful tool for brain decoding. Moreover, this article presents the first use of TV regularization for classification.
arxiv_version.pdf (1.02 Mo) Télécharger le fichier
inria-00563468 , version 1 (05-02-2011)
Vincent Michel, Alexandre Gramfort, Gaël Varoquaux, Evelyn Eger, Bertrand Thirion. Total variation regularization for fMRI-based prediction of behaviour.. IEEE Transactions on Medical Imaging, 2011, 30 (7), pp.1328 - 1340. ⟨10.1109/TMI.2011.2113378⟩. ⟨inria-00563468⟩
554 Consultations
891 Téléchargements
