Combining attributes and Fisher vectors for efficient image retrieval - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Attributes were recently shown to give excellent results for category recognition. In this paper, we demonstrate their performance in the context of image retrieval. First, we show that retrieving images of particular objects based on attribute vectors gives results comparable to the state of the art. Second, we demonstrate that combining attribute and Fisher vectors improves performance for retrieval of particular objects as well as categories. Third, we implement an efficient coding technique for compressing the combined descriptor to very small codes. Experimental results on the Holidays dataset show that our approach significantly outperforms the state of the art, even for a very compact representation of 16 bytes per image. Retrieving category images is evaluated on the ''web-queries'' dataset. We show that attribute features combined with Fisher vectors improve the performance and that combined image features can supplement text features.
douze_attributes_retrieval.pdf (1.63 Mo) Télécharger le fichier
Format : Figure, Image
inria-00566293 , version 1 (08-04-2011)
Matthijs Douze, Arnau Ramisa, Cordelia Schmid. Combining attributes and Fisher vectors for efficient image retrieval. CVPR 2011 - IEEE Conference on Computer Vision & Pattern Recognition, Jun 2011, Colorado Springs, United States. pp.745-752, ⟨10.1109/CVPR.2011.5995595⟩. ⟨inria-00566293⟩
2124 Consultations
4002 Téléchargements
