Automated Refinement of Dependability Analysis through Monitoring in Dynamically Connected Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Model-based analysis is a well-established method to assess the dependability of a system before deployment. It is well known that, in highly dynamic contexts, the accuracy of the analysis results can be limited because unpredictable phenomena may aect the system during its operation. In such contexts, the analysis typically needs to be rened with data obtained from real system executions. In this paper we tackle the issue of rening model-based dependability analysis in automated systems through monitoring. Specically, we report on our preliminary results on the development of a system that exploits the synergic use of an automated approach for model-based dependability analysis and a exible monitoring architecture.
Isads2011Bertolino.pdf (618.95 Ko) Télécharger le fichier
inria-00573405 , version 1 (03-03-2011)
  • HAL Id : inria-00573405 , version 1
Antonia Bertolino, Antonello Calabro, Felicita Di Giandomenico, Marco Martinucci, Paolo Masci. Automated Refinement of Dependability Analysis through Monitoring in Dynamically Connected Systems. International Symposium on Autonomous Decentralized Systems (ISADS) 2011, Mar 2011, Tokyo, Japan. ⟨inria-00573405⟩
Collections
CONNECT
46 Consultations
156 Téléchargements
