Signal and Image processing with FracLab
We describe a software toolbox, called FracLab, for signal and image processing based on fractal and multifractal methods. We illustrate the use of FracLab on a numerical example, and give some new results for estimating fractal parameters in the course of the presentation.
Probabilités [math.PR]
