Software Engineering of Component-Based Systems-of-Systems: A Reference Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Systems-of-Systems (SoS) are complex infrastructures, which are characterized by a wide diversity of technologies and requirements imposed by the domain(s) they target. In this context, the software engineering community has been focusing on assisting the developers by providing them domain-specific languages, component-based software engineering frameworks and tools to leverage on the design and the development of such systems. However, the adoption of such approaches often prevents developers from combining several domains, which is a strong requirement in the context of SoS. Furthermore, only little attention has been paid to the definition of a modular toolset and an extensible runtime infrastructure for deploying and executing SoS. In this paper, we therefore propose a reference framework to leverage on the software engineering of SoS. Our reference framework has been validated on the development of two platforms, namely Hulotte and FraSCAti, to demonstrate that the resulting complexity is isolated in the core toolset, while the development of domain-specific extensions is leveraged and simplified by clearly identified abstractions.
cbse015s-loiret.pdf (350.81 Ko) Télécharger le fichier
inria-00577945 , version 1 (22-06-2011)
  • HAL Id : inria-00577945 , version 1
Frédéric Loiret, Romain Rouvoy, Lionel Seinturier, Philippe Merle. Software Engineering of Component-Based Systems-of-Systems: A Reference Framework. 14th ACM SIGSOFT International Symposium on Component-Based Software Engineering (CBSE'11), Jun 2011, Boulder, United States. pp.61-65. ⟨inria-00577945⟩
336 Consultations
334 Téléchargements
