Competition-Based Model of Pheromone Component Ratio Detection in the Moth - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS ONE Année : 2011
For some moth species, especially those closely interrelated and sympatric, recognizing a specific pheromone component concentration ratio is essential for males to successfully locate conspecific females. We propose and determine the properties of a minimalist competition-based feed-forward neuronal model capable of detecting a certain ratio of pheromone components independently of overall concentration. This model represents an elementary recognition unit for the ratio of binary mixtures which we propose is entirely contained in the macroglomerular complex (MGC) of the male moth. A set of such units, along with projection neurons (PNs), can provide the input to higher brain centres. We found that (1) accuracy is mainly achieved by maintaining a certain ratio of connection strengths between olfactory receptor neurons (ORN) and local neurons (LN), much less by properties of the interconnections between the competing LNs proper. An exception to this rule is that it is beneficial if connections between generalist LNs (i.e. excited by either pheromone component) and specialist LNs (i.e. excited by one component only) have the same strength as the reciprocal specialist to generalist connections. (2) successful ratio recognition is achieved using latency-to-first-spike in the LN populations which, in contrast to expectations with a population rate code, leads to a broadening of responses for higher overall concentrations consistent with experimental observations. (3) when longer durations of the competition between LNs were observed it did not lead to higher recognition accuracy.
2011_Zavada_Plos One_1.pdf (826.78 Ko) Télécharger le fichier
inria-00579546 , version 1 (28-05-2020)
Andrei Zavada, Christopher L. Buckley, Dominique Martinez, Jean-Pierre Rospars, Thomas Nowotny. Competition-Based Model of Pheromone Component Ratio Detection in the Moth. PLoS ONE, 2011, 6 (2), pp.e16308. ⟨10.1371/journal.pone.0016308⟩. ⟨inria-00579546⟩
140 Consultations
60 Téléchargements
