A Comparison of Rule Inheritance in Model-to-Model Transformation Languages - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Although model transformations presumably play a major role in Model-Driven Engineering, reuse mechanisms such as inheritance have received little attention so far. In this paper, we propose a com- parison framework for rule inheritance in declarative model-to-model transformation languages, and provide an in-depth evaluation of three prominent representatives thereof, namely ATL, ETL (declarative subsets thereof), and TGGs. The framework provides criteria for comparison along orthogonal dimensions, covering static aspects, which indicate whether a set of inheriting transformation rules is well-formed at compile-time, and dynamic aspects, which describe how inheriting rules behave at run-time. The application of this framework to dedicated transformation languages shows that, while providing similar syntactical inheritance concepts, they exhibit different dynamic inheritance semantics and offer basic support for checking static inheritance constraints, only.
Fichier non déposé
inria-00582465 , version 1 (01-04-2011)
  • HAL Id : inria-00582465 , version 1
Manuel Wimmer, Gerti Kappel, Angelika Kusel, Werner Retschitzegger, Johannes Schönböck, et al.. A Comparison of Rule Inheritance in Model-to-Model Transformation Languages. ICMT2011 - International Conference on Model Transformation, Jun 2011, Zurich, Switzerland. ⟨inria-00582465⟩
190 Consultations
0 Téléchargements
