Finding Geometric and Relational Structures in An Image - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1990
We present a method for extracting geometric and relational structures from raw intensity data. On one hand, low-level image processing extracts isolated features. On the other hand, image interpretation uses sophisticated object descriptions in representation frameworks such as semantic networks. We suggest an intermediate-level description between low- and high-level vision. This description is produced by grouping image features into more and more abstract structures. First, we motivate our choice with respect to what should be represented and we stress the limitations inherent with the use of sensory data. Second, we describe our current implementation and illustrate it with various examples.
HoraudSkordasVeillon90.pdf (999.05 Ko) Télécharger le fichier
inria-00589995 , version 1 (03-05-2011)
Radu Horaud, Thomas Skordas, Françoise Veillon. Finding Geometric and Relational Structures in An Image. 1st European Conference on Computer Vision (ECCV'90), Apr 1990, Antibes, France. pp.374--384, ⟨10.1007/BFb0014886⟩. ⟨inria-00589995⟩
293 Consultations
295 Téléchargements
