Invariant of a Pair of non-Coplanar Conics in Space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1995
The joint invariants of a pair of coplanar conics has been widely used in recent vision literature. In this paper, the algebraic invariant of a pair of non-coplanar conics in space is concerned. The algebraic invariant of a pair of non-coplanar conics is first derived from the invariant algebra of a pair of quaternary quadratic forms by using the dual representation of space conics. Then, this algebraic invariant is geometrically interpreted in terms of cross-ratios. Finally, an analytical procedure for projective reconstruction of a space conic from two uncalibrated images is developed and the correspondence conditions of the conics between two views are also explicited.
Fichier non déposé
inria-00590053 , version 1 (03-05-2011)
  • HAL Id : inria-00590053 , version 1
Long Quan. Invariant of a Pair of non-Coplanar Conics in Space. Europe-China Workshop on Geometrical Modelling and Invariants for Computer Vision, Apr 1995, Xian, China. pp.190--197. ⟨inria-00590053⟩
39 Consultations
0 Téléchargements
